1960 Oldsmobile Forum • View topic - Trans type
Trans type
Trans type
Postby Phil on Thu Apr 09, 2009 2:50 am
I just picked up a 60 Dynamic 88 rag top. Looking at repair manuels three types of transmisions were used in the 60 Olds. I believe it's a Jet-A-Way but not sure. Can anyone help?
Phil
Phil
Re: Trans type
Postby OldsD88 on Thu Apr 09, 2009 2:11 pm
Do not rely on me, but I think it was a "Slim-Jim," a.k.a. roto hydra-matic?
Re: Trans type
Postby 60Olds on Fri May 08, 2009 1:37 pm
Your Trans is a Jetaway Hydra-Matic Different than the Slim Jim. Better than the Slim Jim. The only automatic used in 1960 depending on if this is a 98 or a Super 88 it will have different enternal parts (valve body etc.) to cope with the extra torque from the 394 compared to the 88's 371. It is a 4-speed trans 4th being 1to1 it won't shift into 4th until 65-70 MPH. I have a factory service manual if you need any more info just let me know.
Good Luck and enjoy the car Brian
60Olds
Re: Trans type
Postby super88dan on Sat May 09, 2009 1:56 pm
There is a letter/number combo stamped on the housing. Truthfully, I had my transmission off the car, staring straight at me and I couldn't figure out where the stamp was. Anyway, certain combos give insight to the tranny. Your indicator on the steering column is another way. My car has RNDSL. It should be a Hydro cuz it's a Super model. Well, I hope I further confused everyone.
Later.
Gee, I'm not too sure what was wrong with me the day I typed the letters for my trans. Yikes, no Park! PNDSLR.
Re: Trans type
Postby 60Olds on Sun Jul 05, 2009 12:48 pm
Hey Super Dan,
Your car has a different Trans than mine. My Trans indicator is PND2LR. Both MY 4DR and my Convertible are this way. Go figure GM did something different and didn't put it in the my Manual.
Did you ever get the info you needed?
60Olds
Re: Trans type
Postby Skidmark on Thu Oct 08, 2009 8:34 pm
60Olds wrote:Hey Super Dan,
So which trans has this indicator pattern? PND2LR?
Skidmark
Re: Trans type
Postby toolbox on Thu Oct 08, 2009 8:51 pm
That's a Jetaway Hydramatic--the 4 speed. I'm actually really surprised to hear that Dan has a different pattern...that's the first time I've heard of that in a '60. The only two tranny options I've heard of are the relatively rare three speed manual and the Jetaway Hydramatic, with reverse in the last shifter position. Pretty sure those are the only two in the shop manual, but I can check when I get home...
