1960 Oldsmobile Forum • View topic - Need to replace leaf springs
Postby misercola on Sun Sep 05, 2010 1:15 am
Hi,
Back end of my convertible is lower than it should be and it looks like I'll need to replace the leaf springs. Can anyone recommend a replacement supplier? Not many listed in Hemmings and they don't seem to carry replacements for the 60.
Regards,
Mark
misercola
Re: Need to replace leaf springs
Postby rocket60 on Sun Nov 07, 2010 1:54 pm
I have replaced the leaf springs on my sceni coupe. I have purchased all the parts from Fusick Automotive. You can find the leaf springs too at Kanter auto products but it's a bit more expensive. Is there a big difference in quality ?? Just make your choice.
http://www.fusick.com
http://www.kanter.com
1960 Oldsmobile super 88 sceni coupe
1960 Olds 98 holiday sedan
rocket60
Postby super88dan on Wed Nov 10, 2010 2:30 am
Well, I bought my springs from Fusick. Nice. They neglected to ask if I required new bolts/hardware. It came down to the week of and the guys I was working with were like... "did you get new bolts?" Almost everybody was looking for $16 each on the bolts. Springs and Things came through at $4 each. They also have the leaf springs. They are in PA. Nice lady answered the phone, helped me out.
http://www.springsandthings.com
88dan
