1960 Oldsmobile Forum • View topic - rear lower quarter repair panels needed
Body, paint, and trim
Postby petey100 on Sat Jan 24, 2009 9:53 pm
I am in need of repair panels for my 1960 dynamic 88 4dr , mine are rotted right out into the trunk just below the moulding. Any help??
petey100
Re: rear lower quarter repair panels needed
Postby toolbox on Tue Jan 27, 2009 9:13 pm
petey100 wrote:I am in need of repair panels for my 1960 dynamic 88 4dr , mine are rotted right out into the trunk just below the moulding. Any help??
There are a few sheet metal pieces available for these...floor panels, and the trunk I know are out there. The lower quarter and bottoms of the fenders are rusted out on a lot of these cars. The lower quarters originally had drain holes in them, but if they get plugged up and any water gets past the trunk seals it sits there until rust makes another drain hole :x . I'm not aware of any aftermarket replacement unfortunately. Repairing that area is going to take either a little sheet metal fab work, or if you get lucky you might find a '60 in the junkyard with good quarters you can transplant in. Do you have any experience with forming/welding, or have any friends that do?
Return to Body and Paint
