1960 Oldsmobile Forum • View topic - Turn signal flasher source?
Interior and Electrical
Postby greg pettit on Fri Jan 16, 2009 4:01 am
I need a turn signal flasher for the Olds. So far I have not been able to find a source. Anyone got any ideas?
Thanks,
Greg
Re: Turn signal flasher source?
Postby Skidmark on Tue Jan 20, 2009 7:27 pm
Got a replacement for mine at pep boys. Maybe that's why my signals are so screwy... are our flashers a special type?
Skidmark
Postby greg pettit on Sat Jan 24, 2009 9:00 pm
Well, the OEM flasher appears to be a Tung-Sol P273D. After searching for this flasher, I discovered several references to the Ideal 222 flasher being a replacement. So far I haven't found either one for sale.
I tried a BUSS 550 flasher, and it didn't work very well..... the signa;s flashed just fine, but the indicator lamps in the dash wouldn't work. After working with the flasher's guts, I was able to get the opposite indicator to flash in the dash.... then after a little more tweaking, BOTH dash indicators would flash at the same time.
Frustrating!
I'm heading to the salvage today, and I'll see if I can grab a flasher out of the '59 Buick I have been eyeballing.
Greg
Postby OldsD88 on Sun Jan 25, 2009 7:00 pm
Have you tried http://www.fusick.com?
Postby toolbox on Tue Jan 27, 2009 9:14 pm
Hmmm...there's GOT to be a source for these. I'll bet GM used the same one for everything that year... I'll see what I can dig up.
Postby greg pettit on Sun Feb 01, 2009 1:58 am
I sure hope you have better luck finding one than I did...lol.....
I ended up grabbing one out of that '59 Buick at my local yard. Plugged it in and presto, everything is back to normal with the flashers.
Greg
Return to Interior & Electical
