1960 Oldsmobile Forum • View topic - Making door panels
Making door panels
Interior and Electrical
Making door panels
Postby greg pettit on Tue Feb 03, 2009 3:10 pm
Well, I finally got tired of driving around in the Olds without door panels. The originals were completely wasted. So, I made some myself, for cheap!
There may be an easier way to do all of this, but since this is my first attempt at any kind of interior work, this was a learning experience.
The first thing I did was to remove the steel upper section off of the original door panels and clean them up real good.
Next, I hung the upper section on the door. Using posterboard, I then made a template of the door , and marked the locations of the handle pivots.
I then transferred the template outline to a 4x8 sheet of Masonite. I got this at Lowe's for less than 8 bucks:
After cutting out the Masonite, I held it in position on the door, along with the upper steel piece. After making small adjustments, I then marked the relationship between the steel and the masonite.
I then drilled 3/16" holes through both to rivet them together. I used contact cement between the pieces as well. Oh, I was worried about the rivets splitting the Masonite board. The fix for that was to use 3/16" washers on the backside of the rivets. It worked like a charm.
Here's what the newly made panel looked like on the car:
Ok, now the door panel needed to be covered. Since the car is not only low buck, but all black, I figured some black carpet might work on the doors. As luck would have it, a friend of mine with a '55 Chevy did his door panels in a nice carpet that was perfect for the job. Believe it or not, it's sold at Autozone as marine/auto material (uv resistant) here for 9.99 per roll. One roll does one complete side of the car.
Anyway, I then traced a line onto the backside of the carpet to make the cut. Using interior spray adhesive, I then glued the carpet to the panel. The edges need to be cut and trimmed to make smooth corners, but overall it was not hard at all.
The result:
I used the same technique on the B pillar post between the doors. There are two sections of trim that cover this area, a steel upper portion which I simply carpeted, and a lower portion which I had to make out of the Masonite.
Thre's another interior panel behind the rear doors, it is made just like the door panels with the steel upper.
Overall I have about 50 bucks in this deal.
Greg
Re: Making door panels
Postby toolbox on Wed Feb 04, 2009 11:41 pm
AWESOME!!! Looks great for $50 :P . Heck, looks better than what I have in mine right now :oops: . That's the same material I made my kick panels out of... The stuff Actually takes paint fairly well (even the metallic I sprayed it with). Seems to adhere just fine...
Sure beats the rotten old ones that were in there...
I'm tempted to do something similar in my car...maybe trim them out in vinyl instead of carpet. The local fabric stores have usually have a decent selection of different vinyl materials...anything would look better than the nothing I have on my drivers door, and the hashed panels I have on the rest of the car :roll: . Thanks for posting this! If you don't mind, I'll turn it into a tech article for the web site...
Postby greg pettit on Mon Feb 09, 2009 12:41 am
Scott,
If you feel like this is tech article material, then by all means feel free to use it.
I agree with you that a person could use real vinyl door panel material instead of the carpet and have a darn nice result.
Greg
Postby undergroundmafia on Sun Jan 09, 2011 4:46 am
nice job! remember that you can use this material for doing fiberglass as well use coats of fiberglass! if you just use the masonite then sand it rough before you apply the fiberglass and you can blend the rivits into the panel and the fabric washer buttons for the screw heads! i do alot of custom work on cars so factory is cool and all but a touch of technology is cool as well! great work allthough that material act's as a lint roller! :mrgreen:
undergroundmafia
Postby super88dan on Mon Apr 18, 2011 10:47 pm
Crazy. Awesome. Nice.
Too bad it's custom stuff. Or, maybe too bad I'm going stock all the way. :x
Return to Interior & Electical
