1960 Oldsmobile Forum • View topic - dynamic88 scenicoupe restoration
Show off your completed project, survivor, or daily driver!
Postby olds 60's on Mon Nov 10, 2008 11:24 am
hello,
I introduce you line take in the car, it is Oldsmobile dynamic88. I bought it in 2004.
in epoch I knew nothing there, I thought that I would run with some months later...
finally, it was à restored entirely...
the motor was frozen, limps her the train before runs away, was done, the interieur and the bodywork also.
I therefore began by making do again the motor, The 371ci of origin had cylinder heads frozen and the scratched shirts, it in summer replaced by one 394ci coming from Starfire on 1964 repaired.
Every joint spy of limp her with speed being also changed.
1960 Oldsmobile 88 Dynamic Scenicoup.
394 V8 ultra-high compression (by 1964 Starfire)
4BBL Edelbrock 750cfm
olds 60's
Re: dynamic88 scenicoupe restoration
Postby olds 60's on Mon Nov 10, 2008 11:32 am
then, I did again the train before. I bought the luxury kit of Kanter
I did also again brakes :P
olds 60's
Postby olds 60's on Mon Nov 10, 2008 11:37 am
the back also :mrgreen:
olds 60's
Postby olds 60's on Mon Nov 10, 2008 11:41 am
refection of the pomp of power steering because it has blown up :mrgreen:
olds 60's
Postby olds 60's on Mon Nov 10, 2008 7:01 pm
some rooms bought on Ebay motor :P
bumpers :
lamp to interieur :
the old:
the same sanding and paint:
once ended :mrgreen: :
I made do again my radiator of heating also, it ran away in the car :oops: :
the old:
the same with a new beam:
olds 60's
Postby greg pettit on Wed Nov 12, 2008 4:09 pm
Very nice! 8)
Did you rebuild the transmission?
Greg
Postby toolbox on Wed Nov 12, 2008 4:32 pm
Awesome job!! That actually looks pretty similar to the work I've had to do on mine...but the body on that one looks like it started out quite a bit better than mine was when I dragged it home. Mine could still use some new rubber parts in the front end...at least the sway bar bushings if nothing else. Still haven't gotten around to doing the shocks either :roll: . I'd love to see more of the interior, if you have any pictures. Anyway, great job!
Postby olds 60's on Wed Nov 12, 2008 7:24 pm
greg pettit wrote:Very nice! 8)
Greg
hello Greg :P
no, I'm not rebuild the transmission. I just changed every seals, oil it and filter it.
in case of worries, I have another two transmision at home (in rebuild) :mrgreen:
olds 60's
Return to Restorations & Survivors
